TXSWoodruff
Aug 23, 2019Aspirant
401 Authorization Error message
Just installed Orbi RBR40 and 3 satellites. Generally working well but receiving a 401 Authorization error on several devices, Apple iPad and iPhone. Other devices working OK. Devices working we...
- Aug 24, 2019
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
brianbarth61
Sep 07, 2019Aspirant
Recently reset my RBR40 back to the factory settings and after that have been getting a lot of 401 unauthorized access errors. This happens even via Chrome or Safari. Orbi router is connected via an AT&T Arris NVG 599. No issues accessing the same sites via the AT&T modum.
ekhalil
Sep 07, 2019Master
brianbarth61 wrote:Recently reset my RBR40 back to the factory settings and after that have been getting a lot of 401 unauthorized access errors. This happens even via Chrome or Safari. Orbi router is connected via an AT&T Arris NVG 599. No issues accessing the same sites via the AT&T modum.
This can be a double router issue.
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (or traceroute 8.8.8.8 if you're using a Mac computer)
- If you see two private IP addresses listed in the first two hops then you have double NAT. Please check the model of your ISP modem and if you have a manual for it.
- If you see only one private address and the second hop shows a public address, then you’re all good and we need then to troubleshoot further to find the root cause of the issue,
- brianbarth61Sep 07, 2019Aspirant
Below is what I get and it appears ok please let me know.
Brians-MBP-2:~ brianbarth$ traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 64 hops max, 52 byte packets
1 dsldevice (192.168.1.254) 5.226 ms 2.103 ms 1.768 ms
2 107-216-40-1.lightspeed.austtx.sbcglobal.net (107.216.40.1) 18.895 ms 8.209 ms 3.443 ms
3 * * *
4 12.123.240.166 (12.123.240.166) 13.522 ms 18.120 ms 12.485 ms
5 12.122.85.197 (12.122.85.197) 16.769 ms 10.185 ms 10.027 ms
6 206.121.120.90 (206.121.120.90) 16.445 ms
206.121.120.70 (206.121.120.70) 10.369 ms
206.121.120.90 (206.121.120.90) 9.923 ms
7 108.170.240.129 (108.170.240.129) 11.426 ms
108.170.252.129 (108.170.252.129) 11.499 ms *
8 108.170.226.57 (108.170.226.57) 16.418 ms
dns.google (8.8.8.8) 13.778 ms 9.983 ms
