la79
Feb 20, 2018Apprentice
401 Unauthorized Access Netgear ORBI
Hello everyone. Lately whenever I try to login into my router via ip address (192.168.1.1) I am faced with a 401 Unauthorized Access screen. I'm asked to put my Orbi Serial number in and I'm forced t...
DarrenM
Feb 22, 2018Sr. NETGEAR Moderator
Hello la79
Have you tried to use a different web browser?
DarrenM
la79
Feb 27, 2018Apprentice
Yes, I was able to try with Mozila Firefox and didn't have that problem. However it seems like it has gone away.
- TommyJayAug 03, 2018Aspirant
This is happening to me too. I'm using both Safari and Chrome browsers and get the same thing. I had been using Comcast and no problems. We then switched to Fios and that's when the problems began. My Orbi is now useless! very frustrating...
I forgot to mention - this is happening to the TV as well. It asks if I'm using this connection in a dorm or hospital or my home. I select 'home', and iNetflixt won't load; I select 'dorm' and Netflix still won't load. very bizarre. Is this related to Fios?
- FURRYe38Aug 03, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
Try a factory reset on the router and set up from scratch. Walk thru the setup wizard on the router with a wire connected PC. Use IE11 or FF browser.
