la79
Feb 20, 2018Apprentice
401 Unauthorized Access Netgear ORBI
Hello everyone. Lately whenever I try to login into my router via ip address (192.168.1.1) I am faced with a 401 Unauthorized Access screen. I'm asked to put my Orbi Serial number in and I'm forced t...
la79
Feb 27, 2018Apprentice
Yes, I was able to try with Mozila Firefox and didn't have that problem. However it seems like it has gone away.
TommyJay
Aug 03, 2018Aspirant
This is happening to me too. I'm using both Safari and Chrome browsers and get the same thing. I had been using Comcast and no problems. We then switched to Fios and that's when the problems began. My Orbi is now useless! very frustrating...
- TommyJayAug 03, 2018Aspirant
I forgot to mention - this is happening to the TV as well. It asks if I'm using this connection in a dorm or hospital or my home. I select 'home', and iNetflixt won't load; I select 'dorm' and Netflix still won't load. very bizarre. Is this related to Fios?
- FURRYe38Aug 03, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
Try a factory reset on the router and set up from scratch. Walk thru the setup wizard on the router with a wire connected PC. Use IE11 or FF browser.
