coptechs
Jan 04, 2018Tutor
401 Unauthorized Access
Recently I've been getting an error trying to log in to the Orbi router via web GUI. The login window pops up, I enter my credentials (and yes, I am using correct password) and Chrome stops respondin...
la79
Feb 20, 2018Apprentice
This has been happening to me a lot lately also. Did you ever find a fix?
Funny thing is that it never used to happen before.
malicarr
May 31, 2018Initiate
Just found this thread guys. Similar problem with only some (but always the same) websites giving the 401/log into server response. Interestingly I when I took my Orbi out opf the loop and coinnected directly to my modem/router the problem was not there. Also when using my Iphone/Ipad/Android device on wifi at work I have no problem accessing sites.
One of the sites I cant access is the Apple App store which is a bit frustrating to say the least.
I didnt have this problem when I first set my system up & have tried a hard reset (including deleting & reinstalling my orbi app) without success and am now awaiting contact from support.
- malicarrJun 01, 2018Initiate
Just to update, after posting above I found a comment on another forum & followed their advice - set my Orbi to AP mode.
It worked a treat & no further problems - Im a happy bunny (but still waiting for Netgear support to respond to my request for support!
Check link below for setting up Orbi as AP:
https://www.bitdefender.com/consumer/support/answer/3603/
