ProblematicOrbi
Apr 01, 2021Aspirant
401 Unauthorized When Trying to Access Web Interface
I get the 401 unauthorized error when I try to access my router settings via the web interface. It doesn't seem to matter what device I use or whether I try orbilogin.net / routerlogin.net or the act...
- Apr 11, 2021
What browser are you using?
Try a different browser? IE11, Edge or Firefox?
When you reset the RBR, try disconnecting the RBR from the modem first. Then try connecting a browser to 192.168.1.1?
Apr 11, 2021Guru - Experienced User
Any progress on this?
Be sure your entering correct values for the log in.
- ProblematicOrbiApr 11, 2021Aspirant
Nope. '
No luck logging in. I can factory reset, set a new password and the problem persists.
I can't even get to the actual login page. I'm immediately prompted to enter my serial number to reset the password, which I've done and it just leads me back to the same place.
- FURRYe38Apr 11, 2021Guru - Experienced User
- ProblematicOrbiApr 12, 2021Aspirant
I've been using Chrome on a PC and an Android device.
I'll try it with IE, Edge and Firefox and see if that helps.
Optical Network Terminal is the ISP device that turns the fibre connection into a usable network connection. I can connect my laptop directly to it and get that sweet sweet gigabit connection. Essentially a fibre modem.
Now I feel silly for not trying this earlier but I managed to login using Internet Explorer.
Any idea why Chrome wouldn't be working to login? Is there a setting I need to change somewhere?
