imberest
Oct 14, 2021Aspirant
401 Unauthorized
Strange, seems like everything with Netgear is falling apart. I can not even type in the forum without any problems. So I have RBR50 which is connected to Virgin Media router(AP mode). I used to have...
- Oct 14, 2021
I don't use Chrome as historically, has not worked well. I use MS Edge and Firefox for FW updates and most router web page operations. Opera for some router operations and configurations changes.
Oct 14, 2021Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
- imberestOct 14, 2021Aspirant
Hello Furry,
Thanks for quick reply.
Did all that and still get to same page
It just happened out of nowhere. I have not entered wrong passwords or anything like that.
Hmmmm...
Just tried on Edge, all works as should.
Is it Chrome started to do stupid things?
- FURRYe38Oct 14, 2021Guru - Experienced User
I have so many smart devices... DHCP setup etc... Start from scratch, omg..
