imberest
Oct 14, 2021Aspirant
401 Unauthorized
Strange, seems like everything with Netgear is falling apart. I can not even type in the forum without any problems. So I have RBR50 which is connected to Virgin Media router(AP mode). I used to have...
- Oct 14, 2021
I don't use Chrome as historically, has not worked well. I use MS Edge and Firefox for FW updates and most router web page operations. Opera for some router operations and configurations changes.
imberest
Hmmmm...
Just tried on Edge, all works as should.
Is it Chrome started to do stupid things?
Oct 14, 2021Guru - Experienced User
- imberestOct 14, 2021Aspirant
I have so many smart devices... DHCP setup etc... Start from scratch, omg..
- FURRYe38Oct 14, 2021Guru - Experienced User
Once it's all set up again, I highly recommend doing this:
I would make one prior to enabling Armor or Circle. Then make one after.
