PAEmpson
Mar 30, 2019Aspirant
404 Error after electricity interruption
I purchase my Orbi in 2017 set up and everything has run smoothly until last week. In the middle of the night our electricity went out and back on approximately 10 times within 30 seconds. Then ele...
Mar 30, 2019Guru - Experienced User
What FW is currently loaded?
Have you reset the RBR and setup from scratch. I would power OFF the ISP modem for 30 seconds then back ON. While the modem is coming back online, reset the RBR and walk thru the setup wizard with a wired PC and a browser connected to orbilogin.com
- plemansMar 30, 2019Guru - Experienced User
agree with FURRYe38 Reset the RBR and the modem and start from scratch.
Did you have a surge protector or a UPS hooked up?
Since I've started buying more expensive of networking gear, I've invested in basic UPS. $40-100 to save several hundreds of dollars of gear is worth it. :)
- FURRYe38Mar 31, 2019Guru - Experienced User
Shouldn't be loosing cnfigurations with or with out a UPS. :smileyfrustrated:
