PAEmpson
Mar 30, 2019Aspirant
404 Error after electricity interruption
I purchase my Orbi in 2017 set up and everything has run smoothly until last week. In the middle of the night our electricity went out and back on approximately 10 times within 30 seconds. Then ele...
Mar 30, 2019Guru - Experienced User
agree with FURRYe38 Reset the RBR and the modem and start from scratch.
Did you have a surge protector or a UPS hooked up?
Since I've started buying more expensive of networking gear, I've invested in basic UPS. $40-100 to save several hundreds of dollars of gear is worth it. :)
Mar 31, 2019Guru - Experienced User
Shouldn't be loosing cnfigurations with or with out a UPS. :smileyfrustrated:
- plemansMar 31, 2019Guru - Experienced User
Agreed but power surges have been known to cause havoc with electronics. I don't know how many times I've had to fix computers caused by power surgers/failures.
- FURRYe38Mar 31, 2019Guru - Experienced User
True...UPS is a good thing.
:heart:
- PAEmpsonMar 31, 2019Aspirant
The ISP - ATT modem is a Motorola NVG-589. I've had this modem 3 weeks. Only changed because my older modem no longer supported a backup battery.
I have restarted my Orbi as a new set-up several times. I have internet service, however I still get 404 errors and I have 1 app I've tried so far that says I don't have internet connection. After about 3 new set-up restarts, I finally was able to use the app without error and did not get the 404 errors. But the next morning, electricity blinked, and now I'm right back where I was before with the app and 404 error. Again I've restarted several times without success. This never happened before . My Orbi is about a year old and of course out of tech support warranty. I'm so frustrated and don't know if it's a netgear cliche or ATT modem problem.
