cmdrTron
Jan 11, 2020Tutor
404 error and other websites won't open.
I have tried to find other posts with this issue and there are a few but none seem to answer or help me solve my issue. I have checked to see my orbi is upto date with the lates firm ware and it is. ...
- Jan 12, 2020
you need to change it in the browser.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
eljarviso
Jan 11, 2020Luminary
If you are using the ISP router as your firewall you can always try switching your Orbi over to run as in AP mode. This is how I run mine.
- cmdrTronJan 11, 2020Tutor
how do i set it to AP mode? i looked in my settings and can't find it on the orbi app.
- plemansJan 12, 2020Guru - Experienced User
- cmdrTronJan 12, 2020Tutor
Thank you very much for the help. solved my problem.
