jgoecke
Nov 24, 2019Aspirant
404 error
I see multiple posts about this issue and even though is says the issue is solved I never really see a solution, or on that I can make sense of. Im not a tech idiot and really want to fix this. I s...
CrimpOn
Nov 24, 2019Guru - Experienced User
Yes, there have been dozens of posts. Each situation may be a bit unique. It will help if you describe:
- When do you receive the 404 error?
When browsing to any/every web site?
When browsing to the Orbi web interface?
Using Mac, PC, iPhone, Android phone (all of them)? - Exactly what is your Orbi connected to (brand/model)?
Is that device in "bridge" (passthrough) mode or router mode? - Is the Orbi in router or Access Point (AP) mode?
Thanks
- jgoeckeNov 24, 2019AspirantSeems to happen with all devices but mostly when going to a link inside another page. I can get to the homepage of a site but then a link to another part gives me the error. Apps like ESPN do not work either on phone and when I turn off WiFi it does. It is not set up as a bridge and I don’t know how to set up the Orbi in AP mode. I do have the WiFi turned off on my router. It is a zyXEL from metronet. I may be able to contact them to set up as a bridge router but would like to just change orbi to AP setting.
- CrimpOnNov 24, 2019Guru - Experienced User
Orbi can be put into AP mode using the web interface. On the Advanced Tab
- FURRYe38Nov 25, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
jgoecke wrote:
Seems to happen with all devices but mostly when going to a link inside another page. I can get to the homepage of a site but then a link to another part gives me the error. Apps like ESPN do not work either on phone and when I turn off WiFi it does. It is not set up as a bridge and I don’t know how to set up the Orbi in AP mode. I do have the WiFi turned off on my router. It is a zyXEL from metronet. I may be able to contact them to set up as a bridge router but would like to just change orbi to AP setting.- jgoeckeNov 25, 2019AspirantProblem resolved. Finally got to website and switched to AP mode. Thanks for help.
