jgoecke
Nov 24, 2019Aspirant
404 error
I see multiple posts about this issue and even though is says the issue is solved I never really see a solution, or on that I can make sense of. Im not a tech idiot and really want to fix this. I s...
jgoecke
Seems to happen with all devices but mostly when going to a link inside another page. I can get to the homepage of a site but then a link to another part gives me the error. Apps like ESPN do not work either on phone and when I turn off WiFi it does. It is not set up as a bridge and I don’t know how to set up the Orbi in AP mode. I do have the WiFi turned off on my router. It is a zyXEL from metronet. I may be able to contact them to set up as a bridge router but would like to just change orbi to AP setting.
CrimpOn
Nov 24, 2019Guru - Experienced User
Orbi can be put into AP mode using the web interface. On the Advanced Tab
