Raygt71
Aug 11, 2020Aspirant
404 errors
I have been using the router plus one sattelite successfully for two months. Suddenly I'm getting 404 errors on all devices. It seems to occur when I click to a link within a website. Then in additi...
- Aug 11, 2020
I just reset everything to factory settings. Once everything rebooted, problem solved.
Mstrbig
Aug 11, 2020Master
Does this happen on all your computers or just 1? Has anything recently changed, such as different devices, software, OS, firmware updates? Try rebooting the Orbi from the WEB GUI, orbilogin.com advanced tab reboot, and reboot the PC.
Raygt71
