nzgroovejet
Jun 30, 2019Follower
404 not found error
When my phone is connected to my Orbi router (RBR20), some links I click on give me the 404 Not Found error. Any ideas? Firmware appears to be up to date (v2.3.5.26) Thanks
Jun 30, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Try a factory reset and setup from scratch...
