nzgroovejet
Jun 30, 2019Follower
404 not found error
When my phone is connected to my Orbi router (RBR20), some links I click on give me the 404 Not Found error. Any ideas? Firmware appears to be up to date (v2.3.5.26) Thanks
michaelkenward
Jul 01, 2019Guru - Experienced User
Some link? So others work?
You say "my phone", what about other devices?
Fl1ntstone
Jul 01, 2019Apprentice
Hi,
This is usually the reason of why you get 404 error:
The HTTP 404 Not Found Error means that the webpage you were trying to reach could not be found on the server. It is a Client-side Error which means that either the page has been removed or moved and the URL was not changed accordingly, or that you typed in the URL incorrectly.
CheerZ
- josedaAug 06, 2019Initiate
this answer is not correct. When I switch to a different network that doesnt uses the orbi router, i do not get the error
- michaelkenwardAug 06, 2019Guru - Experienced User
We have been discussing the issue first raised by nzgroovejet.
Jumping in the middle may or may not mean that you have the same issue.
In any case, "hijacking" is frowned upon:
NETGEAR Community Terms Of Service | Answer | NETGEAR Support
- Behave with civility and mutual respect. Flaming or name calling will not be tolerated. Similarly, any message containing the following will be removed at the discretion of either a Community moderator or administrator:
- Off-Topic posting
- Thread hi-jacking
So, rather than hijacking this attempt to help nzgroovejet, you might do better to start a fresh discussion with your own details.
- TimBentonJan 28, 2020Aspirant
I have the RBR50 connected to a livebox router by ethernet cable and an extender in my office. I get constant 404 error messages, which I do not get direct from the livebox router. This is clearly the RBR50 imposing some kind of firewall.
- michaelkenwardJan 28, 2020Guru - Experienced User
Nothing to do with a firewall. Simply your configuration.
TimBenton wrote:
I have the RBR50 connected to a livebox router ....
Does this mean that you have two routers in series?
The only mentions I can find of the "livebox router" is that it is actually a DSL modem router from Orange.
If so, this explains what you see.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
It may be possible to put the modem/router into modem only (bridge) mode – Google is less than encouraging – and then to use the RBR50 as the router. Sometimes it is easier to put the second router into AP mode.A lof of people have Orbi routers in AP mode. Mine is, after an R7800 router.
One thing still isn't clear to me, the order of your kit. Whichever mode you use, it should be:
> modem > router > extender
I can't work out where the (unnamed) extender gets its connection.
