nzgroovejet
Jun 30, 2019Follower
404 not found error
When my phone is connected to my Orbi router (RBR20), some links I click on give me the 404 Not Found error. Any ideas? Firmware appears to be up to date (v2.3.5.26) Thanks
Fl1ntstone
Jul 01, 2019Apprentice
Hi,
This is usually the reason of why you get 404 error:
The HTTP 404 Not Found Error means that the webpage you were trying to reach could not be found on the server. It is a Client-side Error which means that either the page has been removed or moved and the URL was not changed accordingly, or that you typed in the URL incorrectly.
CheerZ
joseda
Aug 06, 2019Initiate
this answer is not correct. When I switch to a different network that doesnt uses the orbi router, i do not get the error
- michaelkenwardAug 06, 2019Guru - Experienced User
We have been discussing the issue first raised by nzgroovejet.
Jumping in the middle may or may not mean that you have the same issue.
In any case, "hijacking" is frowned upon:
NETGEAR Community Terms Of Service | Answer | NETGEAR Support
- Behave with civility and mutual respect. Flaming or name calling will not be tolerated. Similarly, any message containing the following will be removed at the discretion of either a Community moderator or administrator:
- Off-Topic posting
- Thread hi-jacking
So, rather than hijacking this attempt to help nzgroovejet, you might do better to start a fresh discussion with your own details.
