Retired_Member
Feb 06, 2020"404 not found" when trying to access adminpages
Hi My router suddenly started to show a 404 Not Found when I try to login to adminpages. I asks for username and password and then show 404 Not found. Also tried to access the debug page https://...
Feb 06, 2020Guru - Experienced User
Does http://192.168.1.1/debug.htm work? Don't use HTTPS.
What browser are you using? Try IE11, FireFox or Opera.
Be sure to clear ALL browser caches, exit the browser then re-launch and navigate to the RBRs web page.
- Retired_MemberFeb 06, 2020Firmware: 2.5.1.8
Same problem with http://
Get 500 Internal Server Error
The orbi app also have problem and cannot login anymore. Reboot tried also, but no go- FURRYe38Feb 06, 2020Guru - Experienced User
The RBR is in a bad state, press the reset button in back for 15 seconds then release. Use a wired PC and setup the RBR from scratch.
- FURRYe38Feb 07, 2020Guru - Experienced User
Any progress on this?
Retired_Member wrote:
Firmware: 2.5.1.8
The orbi app also have problem and cannot login anymore. Reboot tried also, but no go- Retired_MemberFeb 07, 2020No progress at the moment, I hope not to lose all my config and do a factory reset. Internet is working as normal but unable to do any changes :)
