Retired_Member
Feb 06, 2020"404 not found" when trying to access adminpages
Hi My router suddenly started to show a 404 Not Found when I try to login to adminpages. I asks for username and password and then show 404 Not found. Also tried to access the debug page https://...
Retired_Member
Feb 07, 2020No progress at the moment, I hope not to lose all my config and do a factory reset. Internet is working as normal but unable to do any changes :)
Feb 07, 2020Guru - Experienced User
I know. A reset will be needed. After doing a reset, and you get things set back up again, please do a backup configuration to file. So if next time something happens and a reset is needed again, you can just load everything up from the back up file. Saves time and headache.
Good Luck.
