raftingbuff
Feb 14, 2023Aspirant
4G LTE cellspot and Orbi satellite
Sorry I am not really a tech person. I have an Orbi RBR50 plugged into my internet with 2 satellites. I just got a T-mobile 4G LTE cellspot that I need to plug the ethernet cable from the WAN port ...
Feb 15, 2023Guru - Experienced User
You should also be aware it can cause a double nat running 2x routers.
Easiest fix is to put the orbi in Access point mode. It does disable some features but tends to be the easiest.
Or you can put the tmobile gateway in passthrough mode.
so you'd go tmobile gateway---->wan port on router----->satellites.
raftingbuff
Feb 15, 2023Aspirant
Sorry I am not a tech person. How do I put the orbi in access point mode? Thanks for all your help!
- plemansFeb 15, 2023Guru - Experienced User
- raftingbuffFeb 16, 2023Aspirant
Thank you!
