Carla1
Jul 08, 2018Follower
4PM26A51099A0 WIFI IS DROPPING ON MY PHONE
Need help my phone keeps dropping the wifi. Nothing else is dropping just my phone. Any suggestion on how to fix this or why it's happening?
Rattler
Jul 08, 2018Guide
Yes. Me too. I have an iPhone X using WiFi calling on T-mobile. It happened on an hour long call about 4 times. I seem to be the only one with problem on our network as my wife has an iPhone 6 and it seems to work well for her with very ocassional dropped call. I am usually staying in the same location, not moving about the house, when it happens. The call just dies and I have to call back. I also had it happen on a call when they came back from being on hold, they couldn't hear me. Weird.
One thing I tried that seemed to help is to turn off UPnP. I saw a post where you adjust the Advertisement Time to Live to 16. I did this, but then decided to simply move the UPnP Portmap list to actual Port Forwarding and turn off UPnP. I havent' really had a long call to test this and I have no idea if it does anything. I was having other problems (2.4gHz Harmony Remote connecting to far away Orbi Sat, not the one in the room) that didn't get fixed with this.
