Waugust
May 28, 2022Aspirant
5 year old Orbi RBR 50 with two RBS 50 satellites
I have a (approximately) 5 year old Orbi RBR 50 with two RBS 50 satellites in a 5,100 sq ft house with 1gb Cox and a one year old Netgear CM1200 modem. Whenever Cox works on their internet I need to ...
- May 31, 2022
Waugust wrote:
So it sounds like the issue is whether or not Cox has updated their cable to the modem, not the cable I used to connect the modem to the router, correct?Not necessarily a Cox issue. When people report WiFi systems not behaving as expected, we often ask questions that are similar to doctors collecting a medical history. The initial post contained a number of questions:
- "Is there a lifecycle to Orbi mesh routers and satellites, and if so, is 4 or 5 years about it?"
No. Electronics will continue to function indefinitely. My RBR50 Orbi is now approaching 6 years old and still going strong.
What happens is that new features often appear that are not compatible with the radio chips in the older WiFi systems.
WiFi6 (and now WiFi6E) use different encoding than the older WiFi5 that our Orbi chips use. I own zero devices that feature WiFi6 or 6E, so buying a WiFi system that supports those new standards would be of no benefit to me. - I'm considering the AXE11000 system hoping for....
That latest, and most expensive Orbi system definitely offers more capability and range if you have devices that can take advantage of it.
And, that newest system appears to be undergoing "growing pains" if posts on the forum are any indication.
My take, "out of the frying pan into the fire."
What this sounds like to me is that the firmware update may not have been entirely successful and the most common advice is to do a factory reset on the system and configure it again using exactly the same WiFi credentials (SSID and password) so that all devices will connect to it.
There have been a number of intermittent issues caused by faulty ISP cable wiring.
If the system becomes stable and works for days at a time, I see no reason for change.
May 28, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Circle, Traffic Meter.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
For any RBKE960 series information and support, please visit this forum:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/bd-p/en-home-orbi-ax
- WaugustMay 29, 2022Aspirant
There is no mfg name on the modem, only Netgear Nighthawk CM 1200. Not a Cox (internet provider) modem, purchased at Best Buy approximately a year ago.
No factory reset since updating the FW. Things have been working since my original post and I'd rather not do that unless the connectivity problem persists.
The modem is in the southeast corner of the 5,100 sq ft house, second floor, one of the satellites in the northeast corner, first floor, the second in the west side of the house, first floor, each well over 30 feet from the modem.
According to the Orbi app, channel 48 is used, 1 and 48 recommended.
I have neighbors all no doubt having wifi but their houses are not as close as has been true in previous neighborhoods with no network stability problems.
DK where to find Circle and Traffic Meter, Armor not used.
I no sooner finished my response and lost connectivity in my home office located outside the main house where I am typing this, possibly the furthest point from the modem, but less than 30 feet from one of the satellites located within the main house. When I walked in the house standing by the satellite, my phone regained connection. The computer in the outside office did not; I had to restart the computer, which now shows 5 bars on the connectivity "fan".
Are 5-year old Orbi product likely to have network stability problems, particularly mine which spent 2 to 3 years very near the ocean with sand dust/salt air? We've since moved inland and have much clearer air.
Time for a replacement or first do a reset? If the latter, do I reset everything (modem, router, both satellites)? What will that do to all the devices currently connected when I bring the network back up?
- FURRYe38May 30, 2022Guru - Experienced User
The Mfr of the modem is Netgear. You have CM1200. I have this modem as well. Good modem.
Lets check the modem out first.
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.htmlWhat is the CAT# LAN cable between the modem and RBR? CAT6 is recommended.
What is the distance between the router RBR and 📡 satellite(s) RBS?
- WaugustMay 31, 2022Aspirant
Thanks for your replies and willingness to help.
Don't know where to find "modems connection status page." Logging into my Netgear account, I find the CM1200, purchased February 2021, but nothing about accessing settings as I do when logged into my Orbi router page. Once there, nothing I recognize having to do with the modem.
I haven't contacted Cox (ISP) about this problem because connecting ethernet to a laptop delivers expected speeds (900+). However, I'm not connected that way long enough to know that stability is or is not an issue. But when the network is down wirelessly, the modem lights indicate all is working. To be honest, I've never been all that confident in what they tell me when I have contacted them previously.
"Be sure there are no coax cable line splitters in the between the modem and ISP service box." What is the "ISP service box"? No splitters in the house as far as I know and none between the modem and the router.
I replaced the ethernet cable between the modem and router but doubt it is RG6. I will order that today for connection between the modem and router and from the router to a Sonos Boost (creates dedicated wifi network for Sonos equipment.)
Not sure how to compute the distance between the modem and satellites. Modem on second floor, satellites first floor. Straight line, modem to closest satellite is the distance between first and second floor of two story house, plus about 35 feet left to right. Distance to second satellite is distance between first and second floor plus about 55 feet.
