PlatinumGoat
Apr 15, 2018Apprentice
5g vs 2.4g
Dear netgear, Please, please, please just let me connect selectively to 5g. Your algorithm to select "the best" band is driving me crazy!!! WTF!!! I just want to have the best speed whatsoever. I al...
- Apr 16, 2018
Netgear could simply do the exact same thing that Linksys did, that is to enable the separation of the 2.4 and 5g bands and let users choose their preferred band themselves. Even with this separation, users could still configure their devices to connect to BOTH bands if they still want their routers to decide for them. In my opinion, if I want hamburger for lunch, don't force me to settle for fish & chips! simple as ABC!
PlatinumGoat
Apr 16, 2018Apprentice
Having tried both the Velop and Orbi in the same surrounding, I concluded that Band Steering (between 2.4 and 5g) or Smart connect as it is also called, is one major limitation of mesh wifi systems. While both the velop and orbi have their own strengths, the algorithm used by both to connect clients to the best band have much room for improvement. Even when standing near a node or satellite with a device in line of sight, 2.4g is often selected first. Can't understand why?
schumaku
Apr 16, 2018Guru - Experienced User
PlatinumGoat wrote:Even when standing near a node or satellite with a device in line of sight, 2.4g is often selected first.
This is mostly depends on the WiFi client - for the same ESSID and the available BSSIDs on air, the client does maintain scoring list. Depending on the uptime, the 2.4GHz often become visible before, because of the band is narrow, and slightly less effort is required to evaluate all the 5 GHz bands.
If there is more bandwidth required and the 5 GHz BSSIDs are comparably in the score, the client does switch very quick.
Aside of doing all that, it does continuously scan for other ESSIDs, stored and unknown ones, and does also maintain a score for these.
One trick often implemented in the bandsteering is to kick-off poor or comparable low standard 5 GHz STA either to another 5 GHz radio where available (to concentrate these on a dedicated radio), otherwise to the 2.4 GHz band.
You simply can't expect that "your" preferred STA is immediately and always connected to what you expect to be the very best right away - like "plug" to the 10 GbE port of there are some 10/100MbE and GbE ports available. Regardless of the AP infrastructure.
- Retired_MemberApr 16, 2018
The answer to all of this is to stop making devices that will only connect on a certain band.
- PlatinumGoatApr 16, 2018Apprentice
- schumakuApr 16, 2018Guru - Experienced User
One network name (one ESSID) and many radios on 2.4 and 5 GHz with individual BSSIDs are much better in any aspect: Radio steering. Band streering. Usability. Fast re-connect. Fast roaming. Plenty of advantages. Support. Mantenance. TCO. Ideally on many APs operated on reduced power to avoid interference. So afraid, I can't back your idea:
SpoilerIndividual names for each band or even worse for each individual radio are a relict from the past.
Yes - I was the bad guy who forced Netgear to remove the ***** limitation not allowing the same network name on multiple interfaces on the same router, the same extender. I would not even had considered to deploy Netgear routers or APs with such a limitation in place. Yes - even extenders here run on the very same name here - the bridging "logic" below is BSSID resp. MAC based anyway.
- schumakuApr 23, 2018Guru - Experienced User
PlatinumGoat wrote:Netgear could simply do the exact same thing that Linksys did, that is to enable the separation of the 2.4 and 5g bands and let users choose their preferred band themselves.
How can this be a solution? If this idea would be part of the technology and standards design - why do most Wi-Fi client STA drivers don't have a control to force it to stick on either the 2.4 or the 5 GHz band? Some advanced drivers allow the configuration of a client to prefer (but not fix) either the 2.4 or the 5 GHz band - but tht's all.
Similar, some 5+ billions of mobile phones have no controls on what band the user does prefer - neither for 2G, 3G, 4G, coming up 5G, or 2.4 GHz or 5 GHz Wi-Fi.
The design of one network name (ESSID) and many BSSIDs (Radio MAC) allowing the clients (to some extent assisted by the access points) to evaluate signal performance and quality and allowing fast roaming is perfectly right. There is no need to guide non-educated users to bad configurations - as it was forced by many vendors in the past on consumer routers. What you are seeking for is a relict from the past.
- PlatinumGoatApr 23, 2018Apprentice
When I had the Velop, before exchanging it for the orbi, I could configure as I wished. The layout and situation in every home is unique and no vendor can claim superiority that their tech is relevant in every case. With the Velop configured into 2 separate networks, I was able to obtain MAXIMUM ISP speeds in every coner of my home. This was and still is my primary objective. I dont't really care about every tech jargon about benefits of ONE SSID or BSSID (whatever that means). As long as I get what I paid for, I'm happy. BTW, I traded the Velop for the Orbi for some other reasons. Thanks anyway.
