tomsliwowski
Nov 30, 2017Apprentice
5GHz backhaul down once a month with firmware 2.0.0.74?
So I noticed something weird the last couple of months. Streaming media from my Plex server (hardwired to the RBR50) to a client wired to a satellite would randomly give errors that the server has di...
Retired_Member
Nov 30, 2017Yes, 2.0.x reduced the range between your router and the sats. You'll need to relocate the sats to keep the 5ghz backhaul connected... commonly reported issue on here... range was greater with pre 2.0.x firmware.
- tomsliwowskiNov 30, 2017Apprentice
They may have reduced the distance but the behaviour I would expect in that case is that it would constantly loose 5GHz signal. This only happens about once a month.
