Vorhilion
Mar 28, 2018Guide
5Ghz channels
Hello, I saw this topic here. But I would like understand why all upper 5Ghz channels are unavailabled for the clients. In Europe, at least in France, we can use the next channels in 80Mhz : ...
st_shaw
Dec 21, 2018Master
I'm not sure what you're saying isn't true. Here in the US, my Orbi is using 80 MHz channel 157 for the backhaul.
I suspect Orbi reserves the right to use DFS channels for the backhaul, if necessary, but it's behind the scenes and not something the user has access to adjust.
ekhalil
Dec 21, 2018Master
I meant the statement that "Unless you allow DFS, which it seems no NETGEAR routers do" :)
In fact, in Europe, only the DFS channels are being used for backhaul in Orbi!
I think that Orbi will select DFS channels also in the US if channels 149-161 (which are allowed in the US) are busy!
Those DFS channels -by definition- are not to be manually selected by users.
