Vorhilion
Mar 28, 2018Guide
5Ghz channels
Hello, I saw this topic here. But I would like understand why all upper 5Ghz channels are unavailabled for the clients. In Europe, at least in France, we can use the next channels in 80Mhz : ...
ekhalil
Dec 21, 2018Master
CrimpOn wrote:
So, it appears that a configuration with only one satellite should turn off "Daisy Chain" so that the one satellite will not tie up 5G bandwidth for no reason?
Correct!
CrimpOn wrote:
Which app was used to produce the channel information?
I use the built-in wifi analyser in my Macbook
Chuck_M
Dec 23, 2018Mentor
So "turning off daisy chain"... depending on who you talk to, you get "Tribal Knowledge" input that perhaps the setting is backwards on the configuration screen. (e.g. checked is actually off)
What is the authoritative way of ensuring daisy chain is turned off? (Is there something you can monitor to see the intended effect was made?
Thanks! Great discussions!
- ekhalilDec 23, 2018Master
Please tick off Daisy Chain in the Advanced Wireless settings to disable Daisy Chain.
You can check that Daisy Chain is disabled by making a wifi scan. You should only see one "hidden" network (network with no SSID) using one of the upper 5 GHz channells with the MAC address of the Router.
If Daisy Chain is enabled you will see one hidden network for every Satellite as well, with the respective MAC addresses of every satellite.
This is what I meant:
If Daisy Chain is disabled, you will only see the Router's Backhaul in the above wifi scan. Notice the MAC address of the basestation in the wifi scan to see if it's the router or the satellite.
- Chuck_MDec 23, 2018Mentor
Great response and makes total sense! Will try Christmas day when I open the second sattelite!! (I peeked!)
Thanks and happy holidays
