Vorhilion
Mar 28, 2018Guide
5Ghz channels
Hello, I saw this topic here. But I would like understand why all upper 5Ghz channels are unavailabled for the clients. In Europe, at least in France, we can use the next channels in 80Mhz : ...
ekhalil
Jan 26, 2019Master
Chuck_M wrote:
How do you list the contents of the directory from telnet? I can see how you can change directories, but I sure would like to see the file structure and contents
ls (for list)
CrimpOn
Jan 26, 2019Guru - Experienced User
I use the unix (linux) "ls -l" command, where -l is the lower case letter L. (Wikipedia has a nice description https://en.wikipedia.org/wiki/Ls)
as in:
cd /var
ls -l
