Basti_Hongkong
Aug 21, 2020Aspirant
95% drop in download speed after router upgrade
After upgrading the firmware to version 2.5.1.16 I encountered a massive drop in download speed. My internet connection is 1,000 Mbit, I typically get between 300 and 800 Mbit (Up and down) through i...
Aug 21, 2020Guru - Experienced User
What are the wired speed test results?
What is the mfr and model# of the ISP modem?
Orbi and v16 is well capable of doing 900Mpbs on wired connections. Mine does.
- Basti_HongkongAug 21, 2020AspirantI still need to test wired speed to the router. I only got one network cable, other one is broken.
ISP Modem is Huawei Echolife HG8040H5- FURRYe38Aug 21, 2020Guru - Experienced User
This modem has a built in router. Have to routers on the same line can cause problems. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATTry wired speed tests first. If you don't get good speed with wired, I would try the Orbi in one of the following configurations:
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopWireless speeds, depending upon design and support, most AC wifi devices will max out at around 400-500mpbs on speed tests. My iphone 6sP gets around 500Mpbs thru the RBR50 with v16 loaded. It get 900Mpbs or just over with a wired PC. However I don't have a gateway modem, a cable modem only.
