Basti_Hongkong
Aug 21, 2020Aspirant
95% drop in download speed after router upgrade
After upgrading the firmware to version 2.5.1.16 I encountered a massive drop in download speed. My internet connection is 1,000 Mbit, I typically get between 300 and 800 Mbit (Up and down) through i...
CrimpOn
Aug 21, 2020Guru - Experienced User
I often ask, "what changed?" In this case, Orbi firmware changed. Although tedious, it is not terribly difficult to download the previous firmware from Netgear's support site and manually "update" (ha, "downdate") to the previous version.
https://www.netgear.com/support/product/RBR50.aspx#download
Click on the "plus sign" and it will show every previous firmware version.
I would do the satellites first by connecting directly to the satellite web page (http://<IP address of satellite>) and then finish with the router.
- Basti_HongkongAug 21, 2020AspirantGreat, I’ll try that
