Zeyad
Oct 01, 2019Aspirant
a device always gets connected to the main ORBI router
Hi I have a device that always gets connected to the main ORBI router, although the satellite is very near to it. Is there any solution for this? So that I can assign it to get connected to the ...
Oct 01, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- willis3Oct 01, 2019TutorMy satellite was only about 19 feet from the router, moving it now
Should I have beamforming on?
Is there a downside to it?- FURRYe38Oct 01, 2019Guru - Experienced User
20 feet is too close. WIfi over lap maybe too much. 30 Feet starting with the RBS from the RBR.
Beamforming is good to have enabled.
Is there a downside to it?- willis3Oct 02, 2019TutorOk moving the Satellite helped some I’ve noticed the ring doorbell using the Satellite for connection.
I think I’ll try turning on beam forming
