Zeyad
Oct 01, 2019Aspirant
a device always gets connected to the main ORBI router
Hi I have a device that always gets connected to the main ORBI router, although the satellite is very near to it. Is there any solution for this? So that I can assign it to get connected to the ...
Oct 01, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
willis3
Oct 01, 2019Tutor
My satellite was only about 19 feet from the router, moving it now
Should I have beamforming on?
Is there a downside to it?
- FURRYe38Oct 01, 2019Guru - Experienced User
20 feet is too close. WIfi over lap maybe too much. 30 Feet starting with the RBS from the RBR.
Beamforming is good to have enabled.
