Zeyad
Oct 01, 2019Aspirant
a device always gets connected to the main ORBI router
Hi I have a device that always gets connected to the main ORBI router, although the satellite is very near to it. Is there any solution for this? So that I can assign it to get connected to the ...
willis3
Oct 01, 2019Tutor
My satellite was only about 19 feet from the router, moving it now
Should I have beamforming on?
Is there a downside to it?
Oct 01, 2019Guru - Experienced User
20 feet is too close. WIfi over lap maybe too much. 30 Feet starting with the RBS from the RBR.
Beamforming is good to have enabled.
- willis3Oct 02, 2019TutorOk moving the Satellite helped some I’ve noticed the ring doorbell using the Satellite for connection.
I think I’ll try turning on beam forming
