Blahue's avatar
Blahue
Follower
Aug 09, 2019
A fix to the netgear Orbi RBR20 disconnecting after firmware update V2.3.5.26
**This is not a issue anymore I fixed it by what I say down below**
I've been having issues with my Netgear Orbi RBR20 (AC2200 Tri-band router) at first I thought it was because of the NBN box but i later was to find that the satelites were disconnecting then re-connecting back to the router and I would drop out of online games but not discord calls I changed my 2.4GHz frequency and that didn't help, but I remembered that I had recently updated my router to the new V2.3.5.26 so I downgraded my router to the previous version of V2.3.1.58 and that has seemed to fix my router and satelites from disconnecting I hope this helps anyone who was having the same or similar issues to myself and I hope if not then they are able to fix there issue
1 Reply
  • How was the upgrade to v5.26 performed? Via auto update or did you manually update with downloaded FW files?
    Was a factory reset performed after updateing to v5.26 and setup from scratch? Try this next time you upgrade FW. Seems to help users after FW updates.
