CarlosFandango
Nov 24, 2018Follower
A mesh of mess?
I live in a long converted barn. Have the Orbi RBK53 with 2 satellites. I have 900mbps internet supplied by Gigaclear. (As far as I know the Gigaclear router cannot have it’s WiFi switched off.) I al...
- Nov 25, 2018
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
michaelkenward
Nov 25, 2018Guru - Experienced User
I have 900mbps internet supplied by Gigaclear. (As far as I know the Gigaclear router cannot have it’s WiFi switched off.) I also have a Sky Q mesh network.
Yes, but can you disable the router bit of the Gigaclear router?
Two routers on your network can cause headaches. For example, you can end up with competing DHCP servers and local address conflicts. To avoid that you may need to set the routers up with the right DHCP and IP address settings.
Unless you have specific reasons for using two routers, to create two separate networks for example, it is usually easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
The Orbi will work in AP mode. Mine does.
