CarlosFandango's avatar
Nov 25, 2018
A mesh of mess?
I live in a long converted barn. Have the Orbi RBK53 with 2 satellites. I have 900mbps internet supplied by Gigaclear. (As far as I know the Gigaclear router cannot have it’s WiFi switched off.) I al...
  • FURRYe38's avatar
    Nov 25, 2018
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
