gr8sho
Mar 10, 2019Virtuoso
A question about 5GHz wireless channel setting
Admitedly I haven't paid much attention to the wireless settings in the management console, but I am aware my RBR50 is using channel 48. When troubleshooting a different issue, I used wifi analyzer ...
JammasterC
Mar 11, 2019Star
How far away is your neighbor?
5GHz channel doesn't travel well through walls and further.distances.
- gr8shoMar 11, 2019VirtuosoNext door. The homes are on 1/3 acre lots so can’t give precise measurement as I don’t know where in his house the router is . But it’s enough to register on the scanner tool.
You’re probably right that it’s not enough to be an interference issue but I’d just as well keep my side clean as possible.
