gr8sho
Mar 10, 2019Virtuoso
A question about 5GHz wireless channel setting
Admitedly I haven't paid much attention to the wireless settings in the management console, but I am aware my RBR50 is using channel 48. When troubleshooting a different issue, I used wifi analyzer ...
Mar 11, 2019Guru - Experienced User
Before MESH and Tri band routers, the signel 5Ghz radio supported channels 36-48 and 149-165. Since the advent of triband, chipset mfrs split the 5Ghz radios into two, one channelization set for 36-48 and the 2nd 5Ghz radio set for 149-165. Now with the advent of MESH, Chipset mfrs use this "wireless backhaul" set on the 2nd 5Ghz radio, hidden and just used between the remote satellie(s) and the base router. Thus only the 1st 5Ghz radio is made user available and configurable on channels 36 - 48 only. Mostly by design and govt communication rules mfr have to follow. DFS is slowly coming to routers. This add more channel availability to wifi routers. Not sure if current gen Orbi will see DFS. Probably next gen.
gr8sho
Mar 11, 2019Virtuoso
Interesting. This may explain the phantom signal I’m seeing on channel 157. Anyway to know for sure the exact channel backhaul is using?
- FURRYe38Mar 11, 2019Guru - Experienced User
Power OFF the Orbi while you watch the scanner app. If it disappears, then re-appears after you turn ON the Orbi, you'll know.
- gr8shoMar 11, 2019Virtuoso
Good idea, but that wasn't it. Unfortunately the Amazon tablet isn't able to see the newer intermediiate channels and it would have made more sense for NG to choose one of those less used channels for backhauling traffic I'll see if I can get my hands on a better tool to check.
At least moving the primary traffic to channel 44 is good enough to have a clean signal there. As for what else is pushing a signal, I suspect the Arris router is still transmitting even though the radios are supposedly turned off and the power output lowered.
- ekhalilMar 11, 2019MasterPlease check this post: https://community.netgear.com/t5/Orbi/5Ghz-channels/m-p/1538610#M26710
And this one: https://community.netgear.com/t5/Orbi/Understanding-Orbi-Radio-Fronthaul-Backhaul/m-p/1671092#M46569
