CrimpOn
Aug 11, 2020Guru - Experienced User
A Triple NAT Experiment
The conventional advice is that there should be only one "router" in a home network, either the ISP device or the user's WiFi router. We offer three solutions: (1) put ISP device into bridge mode, (2...
Mstrbig
Aug 11, 2020Master
Double NAT is not a bad thing, as some continuously post. It might get confusing for a novice, but there are advantages as well. You might run into issues with services that require UPnP support or manual port forwarding.
My office building, until recently, had 3 routers, connected to the ISP router, all setup on separate subnets, (4 NATS), 1 for each leased floor. The 3 routers are now replaced with 3 separate WIFI 6 mesh systems, connected to the ISP router, all setup on separate subnets, (4 NATS), with switches connected for wired devices and the mesh nodes offering great WIFI coverage.
We also install many mesh systems, in homes, where customers want their TVs, Alexa devices, smart devices, etc connected to the main ISP router, and their laptops, PCs, printers, cameras and other network devices that continuously share their connections for access to shared hard drives, viewing local cameras on multiple PCs, print to different shared printers, etc., connected to the mesh system. We never have any problems or see slowdowns or disadvantages using this setup.
