CanyonMonkey
Apr 17, 2020Tutor
A whole home wifi system on one 2.4ghz channel???
I've just set-up my Orbi RBK23 system. Having done an RF survey of the house and garden I determined the best 2.4Ghz channels for each device. Based on the survey I went to assign cetrain devices ...
- May 08, 2020For anyone finding this thread with the same issue I think I've resolved it for the 2.4Ghz band. I haven't yet tried for 5Ghz.
Most of the replies have been less than helpful so I hope this will work for people finding this thread.
Note: I'm using the system in access point mode so can't confirm this works when using the Orbi as a router.
1) Setup Orbi system. All devices will be on the same WiFi channel, in my case ch1.
2) Change the router 2.4Ghz channel to ch6. The satellites will remain on the original channel.
3) Hard reset one of the satellites and set it up as if it were a new addition to the network. It should connect and use ch6, which the router is using.
4) Change the wifi channel number of the router to ch11. You will then have each device on a separate channel.
It's unbelievably weird that Netgear doesn't provide settings to make this process simple but I guess Orbi is targeted at people with limited radio frequency and WiFi knowledge.
Next will come experiments with the 5Ghz settings.
Apr 17, 2020Guru - Experienced User
You'll be fine using manual channels 1, 6 or 11. It's recommended if you have many close nighborss.
You can also turn down the power output of the wifi radios as well. Under Advanced Tab/Advanced Settings/Wireless Settings
CanyonMonkey wrote:
I've just set-up my Orbi RBK23 system. Having done an RF survey of the house and garden I determined the best 2.4Ghz channels for each device. Based on the survey I went to assign cetrain devices to channel 1, 6 and 11 and discover Orbi wants all the devices on the same channel?!
Where can I find the option to manually set the channel number for each device? I guess I'm more likely to get a 5Ghz connection around my property with the Orbi system but it's disappoint that 2.4Ghz settings aren't easily changed.
Retired_Member
Apr 17, 2020Chasing channels and reducing power at the WiFi source is another waste of time and money you spent on your orbi.
- BoilerPlateApr 17, 2020Apprentice
It's why the features are included. And valid steps to try. No trying the features would be waste of time. Like your doing. Please stop. Your not helpful what so ever.
Retired_Member wrote:Chasing channels and reducing power at the WiFi source is another waste of time and money you spent on your orbi.
- Retired_MemberApr 17, 2020
BoilerPlate wrote:It's why the features are included. And valid steps to try. No trying the features would be waste of time. Like your doing. Please stop. Your not helpful what so ever.
And you pointing out your displeasure in my posts is helpful?
