skeetskat
May 28, 2017Tutor
About 3x day disconnects, reconnects instantly
I can't seem to figure out why this is happening but I'm experiencing random disconnects with the Orbi router plus one satellite. I will get disconnected maybe 2-3 times a day but then the system reco...
Retired_Member
May 28, 2017I can almost guarantee it is due to the backhaul signal from the router to the satellite dropping. Several users have this issue and open support tickets but Netgear hasn't addressed it. If you use an app like Wi-Fi Analyzer, you can watch the 2.4 and 5Ghz backhaul signals frequently drop. They are the ones with no SSID.
It's probably happening much more than 3x per day but it is very quick and doesn't always last long enough to drop every device.
- JMU1998May 28, 2017Luminary
Yes this issue has been around for a while happens in AP mode as well, keep telling myself Firmware fix is coming but thus far useless Firmware releases.
- skeetskatMay 29, 2017Tutor
JMU1998 wrote:Yes this issue has been around for a while happens in AP mode as well, keep telling myself Firmware fix is coming but thus far useless Firmware releases.
Well that gives me hope it will be fixed via firmware at some point as it doesn't seem to be an issue specific to my setup...here's hoping since other than that, the speed and coverage have been great.
It's probably happening much more than 3x per day but it is very quick and doesn't always last long enough to drop every device.Yeah that makes sense to me...hopefully it is fixed via firmware soon... :/
