77PALE77
Apr 05, 2019Apprentice
About printer through ORBI
Hi guys,
I recently extended my wi-fi with ORBI. Let’s call the original wi-fi WIFI1. ORBI is connected to the WIFI1 modem via ethernet with its IP (192.168.1.100) and generates a new wi-fi signal:...
- Apr 06, 2019
Thanks a lot, it now works fine.
I only had followed the setup instructions and it had set as two routers one after the other.
Now it is in AP mode and the only one anomaly is that I connected to the ORBI router an audio device via ethernet and it isn't shown within the connected devices. Strangely it is shown with 192.168.1.106 IP in the modem/router, but anyway it works fine.
But in AP mode it seems impossible to remotely access the ORBI (te selectioni s shown in grey and cannot be activated): is that right?
Thanks again
Pale77
CrimpOn
Apr 05, 2019Guru - Experienced User
What device(s) are attempting to use the printer from the Orbi Wi-Fi? (i.e. desktops, laptops, PC, Apple, tablets? etc.)
I think the problem will "go away" if the Orbi is set into Access Point (AP) mode. On the Advanced tab, select Advanced Setup, select Router/AP Mode. In general, it is not a good practice to stack one router behind another. When every device is getting an IP address directly from the first WiFi router, devices should "find" the printer with no problem.
- 77PALE77Apr 06, 2019Apprentice
Thanks again
Pale77
- FURRYe38Apr 06, 2019Guru - Experienced User
When in AP mode, some features like remote access are no longer enabled.
- 77PALE77Apr 07, 2019ApprenticeThanks for the answer, now it’s clear.
But what about the device connected to the ethernet port which is invisible to the Orbi?
Pale77
- randomousityApr 07, 2019Luminary
Since having two routers working in router mode is generally bad, and double-NAT can cause problems, you're best off either leaving the Orbi in AP mode and using the modem/router as your router, or, alternatively, putting the modem in bridge mode (terminology varies by model), so that it's only a modem for practical purposes, and then using the Orbi in router mode. Which way you do it depends on which one has better features, etc. If, for example, remote management is important to you, and the modem doesn't offer that, then I'd put the modem in bridge mode and use the Orbi in router mode.
