bormikstel5
Jun 18, 2020Follower
Absurdly Slow Speeds from Orbi RBR50
I have had the Orbi RBR50 and satellite for over a year now with no problems. Recently, download speeds have gone from 40 mb/s to 1 or 2 mb/s. This happens for about an hour, and then returns to no...
Jun 18, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
