gawalla
Jun 01, 2020Aspirant
Absurdly slow speeds from outbuilding Satellite
Hello I am hoping to get some help on bad speeds and dropped coverages. I've recently moved into a house with an outbuilding pool house about 150' away. Internet is FiOS and of course, it comes in...
CrimpOn
Jun 01, 2020Guru - Experienced User
An Orbi satellite connected directly to the router with ethernet cable should provide the same performance level as the Orbi router.
When you look at the Orbi web interface "Attached Devices", what does it show for the pool house satellite?
(how is it connected?)
- gawallaJun 02, 2020AspirantThat’s the weird thing - it shows up with a solid line/wired and is rated as “good” On the web interface and with a green indicator in the app.
From appearances it should be functioning.
Overall there seems to be an incredible diminution of speeds on the Orbi WiFi - even the router shows no more than 50-60, sometimes a spike to 100, speeds while plugged directly into the FiOS router. And the pool house is another order of magnitude below everything else.- plemansJun 02, 2020Guru - Experienced User
many fios ont's have an integrated router.
have you seen this article?
https://kb.netgear.com/23977/Will-my-NETGEAR-router-work-with-Verizon-FiOS
If you have, how do you have the fios router and the orbi router configured?
- gawallaJun 02, 2020AspirantYes - that’s exactly what I have - the FiOS WiFi has been disabled and Orbi is running in AP mode
