OrbiQuestions
Mar 23, 2020Aspirant
AC 3000 (RBR 50) - some internet sites ask for login/password now
I purhcased an AC 3000 router/one satellite last week. Works great. Both my wife and i have noticed that certain websites no long longer load asking for our username and password before taking u...
OrbiQuestions
Mar 25, 2020Aspirant
Hello,
ATT doesn’t allow bridge but I did enable pass through/DMZPLUS and I was able to shut off the WiFi. I was also able to login to the Orbi and enable AP mode. Thank you this solved our problem.
However I am having work VPN issues today. Is this a co. Issue? Or is a VPN connectivity issue a bi-product of the changes I made above?
Thanks
Thanks
Mar 25, 2020Guru - Experienced User
Ok.
Any VPN issues would not be or should not be effected by what you did, however DMZ and IP pass thru is not needed since you configured the RBR for AP mode. DMZ or IP passthru is only needed if you use the RBR in router mode.
- OrbiQuestionsMar 25, 2020AspirantDo I need to turn off the pass through? ie is it hurting anything by having it on?
Thank you again for all your help.- FURRYe38Mar 25, 2020Guru - Experienced User
Yes, it would be a security issue since your by passing the firewall on the modem. If you had the RBR in router mode then the RBRs firewall would be used.
