Maddie459
Jun 19, 2021Aspirant
AC Adaptor
Hi everyone , I have a orbi rbr20 with 2 satelites rbs20. All is working fine until 1 of the AC adaptors stop working . Not sure how best to replace the adaptor which is input of 220-240V , 50-60Hz ...
Jun 19, 2021Guru - Experienced User
Netgear doesn't sell replacement power supplies.
But you can use any power supply so long as it has matching output voltage and polarity and at least the same amperage.
It can have more amperage but I wouldn't go less.
- Maddie459Jun 19, 2021Aspirant
Thank you very much !
Have a good day !
Maddie
