Maddie459
Jun 19, 2021Aspirant
AC Adaptor
Hi everyone , I have a orbi rbr20 with 2 satelites rbs20. All is working fine until 1 of the AC adaptors stop working . Not sure how best to replace the adaptor which is input of 220-240V , 50-60Hz ...
michaelkenward
Jun 20, 2021Guru - Experienced User
As plemans says, it will probably have to be a generic adapter. I chip in only to say that you can often find these in the usual places and many will go so far as to claim compatibility with Netgear devices.
First, dig around at home. You may have something lying around from an old device that will work. Follow the advice from plemans on what to look for.
Maddie459
Jun 20, 2021Aspirant
Much appreciated !
