Misquet
Sep 26, 2021Tutor
AC Power adapter Orbi RBK353
Hi, I need a AC Power Charger for the Orbi RBK353 (Europe/Holland Version). I assume you can also use universal chargers however I am not sure which type? Can you please help? Thanks a lot
- Sep 26, 2021
According to the manual:
North America: 120V, 60 Hz, input
UK, Australia: 240V, 50 Hz, input
Europe: 230V, 50 Hz, input
All regions (output): 12V, 3.5A DC outputSo you'd want a 3rd party supply with a 12v 3.5amp output.
Sep 26, 2021Guru - Experienced User
yes you can use a 3rd party power supply. You just have to make sure it has the same voltage and polarity output as the original. It can have higher amperage but not lower.
Misquet
Sep 26, 2021Tutor
Thanks for you're help.
Do you perhaps have suggestions?
I have bought a set of 3 without the power supply (not shipped / received yet) and want to order however not sure which one to order?
- plemansSep 26, 2021Guru - Experienced User
- MisquetSep 26, 2021TutorThank you so much.. I really appreciate it. Do you perhaps also know what the diameter is of the connector?
I don't. Sorry!
the specs don't show it and I don't have one.
Tried looking up the fcc info but didn't find it in a language I could read :)
