Misquet
Sep 26, 2021Tutor
AC Power adapter Orbi RBK353
Hi, I need a AC Power Charger for the Orbi RBK353 (Europe/Holland Version). I assume you can also use universal chargers however I am not sure which type? Can you please help? Thanks a lot
- Sep 26, 2021
According to the manual:
North America: 120V, 60 Hz, input
UK, Australia: 240V, 50 Hz, input
Europe: 230V, 50 Hz, input
All regions (output): 12V, 3.5A DC outputSo you'd want a 3rd party supply with a 12v 3.5amp output.
Misquet
Sep 26, 2021Tutor
Thank you so much.. I really appreciate it. Do you perhaps also know what the diameter is of the connector?
michaelkenward
Oct 01, 2021Guru - Experienced User
See my other answer to this question which, thanks to bad advice from someone else, now appear several times.
Orbi Rbk 353 - NETGEAR Communities
As I suggested there, look for an adapter with swappable tips.
There is nothing special about Orbi devices. Same sort of adapter as Nighthawk stuff, switches even. If you have one of those, the tip will almost certainly be the same size. I've tried them.
