mrdbarnes
Oct 16, 2020Aspirant
AC Power Adapter
I purchased an RBR20 Mesh router with 1 Sattelite from Costco. The specs I was looking for were not on the package but I took a chance. MOST of the equipment I purchase have power adapters that accep...
Mstrbig
Oct 16, 2020Master
I have rerad where the US power supplys are 240 compatible, but I don't know for sure.
So as to not take the risk of blowing it, You could get one off Amazon or other sites for around $20 US.
Any generic power supply with the right volts and enough amps will work as long as it has the right "tip" size and (+/-) polarity.
- mrdbarnesOct 24, 2020Aspirant
SOME of the Netgear adapters are 240V compatible but the one supplied with THIS model indicates the voltage range ONLY to 120V. Netgear is non-responsive as to whether or not they have a 240V adapter for this unit.
As I mentioned, I have voltage transformers in use and what a PAIN to seach a match for V/A/and tip. Next "upgrade" I will be more careful. A pity that the tech specs are not printed on the box like many other devices.
Thanks for your reply!
