Maartenorbi
Jan 22, 2020Aspirant
AC2200 Orbi Micro Router no internet access
After installing yesterday my new Orbi system everything worked perfect. Today I came home and noticed that I have great wifi signal but no internet access(wifi symbol plus Exclamation mark). Yet, I...
CrimpOn
Jan 22, 2020Guru - Experienced User
It would help if you can identify:
- Which model of Orbi. "AC2200" is a description of speed, not a model.
Orbi routers have names like RBR20, RBR40, RBR50, etc. - Where do you see this WiFi symbol with exclamation mark?
- How did you set up and manage the Orbi?
(Orbi web interface or Orbi "app")
Thanks
Maartenorbi
I managed to make a screens hot while logged in on my app.
It shows that my chrome cast is used different signal hertz.
- CrimpOnJan 22, 2020Guru - Experienced User
It appears you have three devices on the Orbi. Do all three of them display this "No internet" symbol?
Which device are you using now to access the forum?
Thanks
- MaartenorbiJan 22, 2020AspirantI'm using my own phone Huawei with has he no internet signal on my screen. The android I didn't check and my girlfriend is using iPhone and it's connected w
WITHOUT the exclamation mark. (weird)
