Maartenorbi
Jan 22, 2020Aspirant
AC2200 Orbi Micro Router no internet access
After installing yesterday my new Orbi system everything worked perfect. Today I came home and noticed that I have great wifi signal but no internet access(wifi symbol plus Exclamation mark). Yet, I...
Maartenorbi
Also my next printscreen is kinda disturbing haha
CrimpOn
Jan 22, 2020Guru - Experienced User
Yes, the Red dot indicates no internet. Obviously a little misleading since you are actually using the internet.
Which specific internet modem (brand, model #) is the Orbi's yellow (WAN) jack connected to?
- MaartenorbiJan 22, 2020AspirantIt's connected to a: zyxel VMG8825-T50
- FURRYe38Jan 22, 2020Guru - Experienced User
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
